My vent fan in the dash is starting to work when it feels like it. Is this a hard item to find for replacement or hard to install? I am going to redo the dash soon and thought at that time it would then be the best to replace it. Any idea's or comments are welcome! Thanks, Mark
You will find the fan under the hood,behind the the dash. To remove it there a two screws and a plug,then slide it out of the duct unit. If it is operating intermitantly on it own it sound more likly to be the switch or wiring. I had trouble with my fan not working and had to fit new brushes. Good luck.
John: Where did you purchased the new brushes? Thanks.
I got them from a local electrical motor repair company. I took the old ones in and they found me some the same size. They were very cheep as well.
Thread Tools | |
Rate This Thread | |
