Nobody
bob tilton's Avatar
Post key question
hope everyone doesn't mind a question from a 911 owner but i figure this is also a good place to ask considering the model years.
so i figure it's time to address my ignition/door key situation.
non-original ignition key has the following info stamped on it:
-taylor USA, P79Bm measures 2 1/8" in height, works fine.
-non-original door key: ilco DM4, 1 7/8" in height, opens driver door, does not open pass door but can be inserted without turning.
-door handles are correct for the year.
i have read over the pelican article and suspect i will need to run thru the tumblers for the pass side.
i question why i have two different style keys as i thought i should have ONE key that fits all, correct? if so which key is incorrect? where do i get replacement keys? i've only seen blanks avail for '69+. even if i re-do the tumbler pins i would still have 2 different keys. what's the deal?
tia,
bob
'68 911L
[This message has been edited by bob tilton (edited 08-31-2001).]
Old 08-31-2001, 09:19 PM
912s's Avatar
Post
I had responded to a question similar to this a while back and had made note of the Pelican article. Since then I have contacted a local locksmith, and for $25 he will rekey both doors to match my ignition and provide me with a spare key. The price was based on me dropping off the door locks and my current ignition key.
Scot
'67 912
http://www.geocities.com/ford10n/
Old 09-01-2001, 01:05 PM
Nobody
bob tilton's Avatar
Post
thanks scot, this helps me out a lot.
bob
Old 09-01-2001, 04:02 PM
