Nobody
hope everyone doesn't mind a question from a 911 owner but i figure this is also a good place to ask considering the model years.
so i figure it's time to address my ignition/door key situation. non-original ignition key has the following info stamped on it: -taylor USA, P79Bm measures 2 1/8" in height, works fine. -non-original door key: ilco DM4, 1 7/8" in height, opens driver door, does not open pass door but can be inserted without turning. -door handles are correct for the year. i have read over the pelican article and suspect i will need to run thru the tumblers for the pass side. i question why i have two different style keys as i thought i should have ONE key that fits all, correct? if so which key is incorrect? where do i get replacement keys? i've only seen blanks avail for '69+. even if i re-do the tumbler pins i would still have 2 different keys. what's the deal? tia, bob '68 911L [This message has been edited by bob tilton (edited 08-31-2001).] |
I had responded to a question similar to this a while back and had made note of the Pelican article. Since then I have contacted a local locksmith, and for $25 he will rekey both doors to match my ignition and provide me with a spare key. The price was based on me dropping off the door locks and my current ignition key.
Scot '67 912 http://www.geocities.com/ford10n/ |
Nobody
thanks scot, this helps me out a lot.
bob |
