Post Heat exchanger
I have a '69 912 with perhaps bad heat exchangers. I have exhast fumes in the cabin when I pull up on the heat lever. I'm thinking the heat exchangers are bad. How do I remove these (looks like two bolts -- one at top and bottom)? How do I tell if they are bad? Are there other replacements that are not as expensive?
Dave
Old 10-05-2001, 08:50 AM
Efrain68912's Avatar
Post
If you have exhaust fumes in the cabin, I ink you have bad heater boxes (the ones that connect to the exhaust). Don't know if (or where) replacements are available.
Efrain
68 912
Old 10-07-2001, 11:34 PM
Senior Member
Post
Hello
Those fumes where generatet by burnt oil and are not a sign from a bad exhanger. they are a sign from a oilleak wandering inside the exhanger trough a gap or a rusthole.
Exhaust gases are hard to smell only if the mixture is to rich.
Removing them is very simple by just removing the J pipes yet it sound simple but geting on that spot says use good tools and be patient.
Grüsse
Old 10-08-2001, 02:08 PM
WFBowen's Avatar
Post
If you have even the slightest feeling that you're getting exhaust through the heater ducts keep that heater lever off. CO poisoning is a very subtle and extremely dangerous proposition.
Old 10-08-2001, 03:38 PM
