hole in 912 case behold the carnage hahaha
As I was cleaning my crankcase today, preparing for my rebuild I noticed a hole in the corner closest to the #4 cylinder. check outh the pictures. What are my options. does this need to be fixed. The only reason that I am unsure if it needs to be fixed is that ,unless it is structural, all it does is keep oil from entering the front cover from the crankcase. I don't want to have this fixed if I don't have to.
Wow that's interesting, did you find the broken piece or pieces in the crankcase? A welder with proper equipment can do the repair.
Chas. 69/912
Thank you, Your Welcome! and Best of Luck.... Chas. 356912911 |
I still have a part of my crank that went completely through my case. I use it as a paperweight and reminder. The Maestro sent it to me after my "Turkey Engine" was turned into a solid powerplant.
abit off center
That hole is part of the casting, its supposed to be there. What? did you have a crank break? Usually with a broken crank you loose your end play and it takes out the center main bearing. yours case looks fine.
Craig
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
thanks craig, thats a relief. I'm 99% sure that a crank never broke in this case. The bore is good and measues to the standard specs. The hole looks pretty clean from the outside but inside it's a little jagged as if it broke. Are all 912 cases like this?
912
abit off center
John, it should be the same for all 912 engines, at least its on my 67 (pic enclosed) and my 69 case those are 616/36 and 616/40 cases.
Craig
