| Registered |
				Help, what did I do to my engine?
			I rebuilt my stock 1968 912 with a big-bore kit 2 years ago, and without driving it more than a few hundred miles, have been storing the car for the last year and a half.  I took it out of storage today to get it road ready for driving this summer.  While "airing it out" a bit on a local back street, the throttle linkage stuck the pedal to the floor.  I mistakenly pushed in the clutch before I got the key off and I pegged the tach for more than a full second.  I pushed it to the garage, got the throttle unstuck, but now the starter sounds like its turning over the flywheel, but the pullies on the back end of the engine aren't turning when the thing turns over.  What do you guys think I broke?  What should I do next to figure it out?
|  04-30-2004, 09:59 AM |
| Registered Join Date: Jul 2002 Location: Just East of Atlanta
			the big part that controls everything is broken... drain the oil...watch for particlulate...pull the sump cover off, and then peek up inside... that should tell you everything. sjd
				__________________ Porsche sold, moving back to muscle cars for a bit. | ||
|  04-30-2004, 10:48 AM |
| Registered |
			gulp.. dont sound good...    what steve said.. sounds like a crank, or maybe some bearings.. either way, its rebuild time.
				__________________ Harry Hoffman 68' 912 Coupe 'Fritz' burgundy red (6808) | 67' 912 Coupe 'need parts?' 912 Registry charter member #912R0195-C | Early 911S Registry member #2070 http://hoffman912.blogspot.com/ | ||
|  04-30-2004, 09:58 PM |
			or subaru conversion time.   sjd
|  05-01-2004, 04:31 AM |
| 912 Join Date: Sep 2002 Location: The Netherlands
			Probably sheared dowel pins on the cranckshaft, which are locking the flywheel. Now they are broken you can turn the flywheel but the rest, cranckshaft, pistons etc don't move... So everything has to come out again...
				__________________ 67 912 coupe ivory on black 68 912 targa slate gray on red leather | ||
|  05-03-2004, 12:34 AM |
