porschedreamer's Avatar
Send a message via AIM to porschedreamer Send a message via Yahoo to porschedreamer
F.I to CARBS "type 4 conversion to 912"
Greetings Porsche Gurus!
Im collecting parts for a type 4 conversion. I see an engine on the local paper that indicates:
-->PORSCHE 914 1.8 liter motor good condition complete except for fuel injection
How HARD is it to have CARBS in this sucker instead of fuel injection? What does it entail?
I imagine a set of carbs and manifolds?
I know i should probably post this on the 914 forums, but everyone knows that the 912 guys are cooler and smarter than the 914 guys! hahhahaa
http://porsche.edbot2000.com
Old 07-17-2004, 11:53 AM
Steve F's Avatar
Cool
Hello, there is reams of info on that subject at this site
http://shoptalkforums.com/ the Type 4 forum is your best bet.
Cheers
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 07-19-2004, 07:11 AM
Griznant's Avatar
It's not difficult, a carb kit basically "bolts on". The trick is that the distributor for the fuel injection is probably not the best thing to work with carbs, so you will need to switch over to a Bosch 050 (the 009 is not a good match to the Type 4 due to the curve, total advance, and the retard on #3 which is not needed on the T4). The cam is probably not going to give you what you want with carbs either since it is setup for EFI. However, it WILL run, but you won't be making the most of your power. For a stock 2.0L, a set of Weber 40s is more than enough. Also, you do not want to run the stock phenolic manifold spacers on carbs. Not enough heat is transferred through these to the manifolds to keep the carbs from icing up when it gets colder out. Run the thinner paper-like gaskets that come with most kits.
I'm running a fairly stout 2056 in my '69 with Dual 44 Webers, and it screams like a banshee. I'm more than happy with the conversion, and would do it again in a heartbeat (except maybe throw a stroker crank in it for a little extra punch).
Later,
G
Old 07-22-2004, 04:59 AM
