912E #444
Fuel lines
Yes... I've had my gas leak episode and all the rubber lines are being gone thru and changed regardless of how they look!
912E #444 Former Formula 2000 / Formula Ford piloto. "Butzi" http://forums.pelicanparts.com/porsche-912-technical-forum/397159-912e-newbie-how-am-i-doin.html |
Good for you. Better to be safe than sorry. Ron
912E #444
Small progress
Had a chance to get some work done on Butzy last rainy Saturday. In preparation for installation of the rebuilt pedal cluster, I wanted to apply some Rust Prevention to the cockpit floors.
I had the pedal cluster sent of to Bruce in California and $235 and 10 days later I had a work of art with nickel plating and powder coated re bushed result. Well worth the cost, highly recommended! ![]() ]
912E #444
Pedal Cluster rebuild
Pedal Cluster rebuilt
Hi Test Gas?
These cars run on regular gas... The Compression ratio is relatively low. I've got a high mileage car (237K) that has never missed a beat in 15 years and never had a taste of the good stuff. I know you'll enjoy your "E". They are fun to drive and bulletproof.
David Ferlauto San Jose CA 1969 912 2001 Beck / Porsche 1976 912 E |
912E #444
Well Dan, the owner of MVP Automotive and my personal friend is spearheading the work on 'Butzy' and found twoleaky iinjectors and a cracked air intake and some other small issues so now the motor starts at the first few revs of the starter and actually idles!
If Dan could I know he would like to have hands on at every stage but he has a business to run. I'm glad when he does apply his magic touch at any opportunity! More to come for #444!
912E #444
Looking for Left and Right Rocker Panels
These rocker panels are special order and nearly $400 each so Glen from the Parts Dept recommended I post to see if anyone has these? 911 559 113 01 grv , 911 559 114 01 grv See the pic attached... Item #6 Is this the best place to post this? Thanks The rubber moulding strip is removed and the Rocker Panel below is un bolted. The Rocker Panel runs from the front wheel well to the rear wheel well. ![]() ![]()
912E #444
New Rocker Panels have been acquired and Jack receiver tubes are on the way so now it's time to sort out the stuck/vandalized sunroof!
While in outside storage last winter at my mecahanics shop some jerk tried to jump through the sunroof... So now besides stuck cables and such. more work straightening out dings! ![]() Onward and Upwards!
That sucks that some idiot jumped on your roof - what's wrong with these people??
From what I can see it looks like the seals around your sunroof are non-existent. That might be letting rain water in and could be the reason you have water collecting in the rear footwells. When you open the sunroof you will see drain holes in each corner of the roof opening - check that these are not blocked too. I've been trying to get the sunroof on my 912E to work for a while now. My seals were very worn and missing completely in some areas. The cables were totally seized/rusted inside guide tubes at the back of the sunroof mechanism. I had to cut them to get them out. I had to get new guide tubes and I initially bought used cables which haven't really worked. I'm on the lookout for new or NOS cables - they are quite expensive. I closed mine back up and will try and tackle it at a later date. I did put in new seals so at least no more water is getting in. |
912E #444
Looking for Air Flow Sensor p/n 923-606-111-00
I need help finding this NLA Air Flow Sensor, part number 923 606 111 00
Any advice is much appreciated! Regards Paul
912E #444
Thanks for the reply!
Paul
912E #444 Former Formula 2000 / Formula Ford piloto. "Butzi" http://forums.pelicanparts.com/porsche-912-technical-forum/397159-912e-newbie-how-am-i-doin.html Last edited by racerpaul; 01-14-2015 at 10:24 PM.. Reason: spelling |
912E #444
2016 Update
Update: Rust remediation has been undertaken by my good friend Master Mechanic Dan Haynes the owner and founder of MVP Automotive in the new Brookhaven location.
Both Jack Receivers were purchased through our host's here at Pelican Parts and the older perished receivers were cut out and replaced with some amount of fabrication of frame rails needed. Pics: ![]() Rocker Panels were removed and more rust repair completed. I was able to acquire a pair of like new but used Rockers again through the Parts Wanted Forum here at Pelicam Parts. The are even the same color! But will be resprayed of course when the project heads to the paint booth. Dan and his guys did a great job even providing such details as chip guard and primer. Pics: ![]() ![]() ![]() ![]() ![]() More to follow, we are getting close to finishing 'Butzi'! I am hoping for an early Fall unvilimg... we are entering August next week already. It has been a while. Paul
912E #444 Former Formula 2000 / Formula Ford piloto. "Butzi" http://forums.pelicanparts.com/porsche-912-technical-forum/397159-912e-newbie-how-am-i-doin.html Last edited by racerpaul; 07-23-2016 at 03:39 PM.. Reason: duplicate pics / spelling |
Andy Bullen
great work, I'm about to rebuild my pedal box as well - do you have any more pics of it?
76 912E - Grocery Getter 04 Toyota TacomaTRD - Beater Truck 08 Honda OdysseyEXL - Family Hauler |
912E #444
Andy,
No other pix of the pedal quadrant except for the one I posted... this upgrade and refurbishment of the pedal bushings is a must.... comes back better than new! Paul
Andy Bullen
Absolutely Paul, my accelerator cable currently gets stuck under the tunnel if pushed past a certain point and results in WOT because of worn factory plastic bushings.... Bronze bushing kit is on order, so that never happens again....
912E #444
Andy, that has got to be an eye opener!
912E #444
912E Master Mechanic Dan Haynes!
Here are a few quick videos of my friend Dan, Master Mechanic and owner of MVP Automotive Bellport and now the new Brookhaven location.
Dan is the only one allowed to lay his magic hands on 'Butzi's' Mechanics! Working a little magic on the idle at start after some injector work... http:// Indulge me and Enjoy! Paul
912E #444 Former Formula 2000 / Formula Ford piloto. "Butzi" http://forums.pelicanparts.com/porsche-912-technical-forum/397159-912e-newbie-how-am-i-doin.html Last edited by racerpaul; 07-28-2016 at 06:27 PM.. Reason: spelling |
912E #444
Time for new shoes!
Getting ready for the paint shop so about time to consider ordering new soes! A set of Pirelli's or??? Need some advice!
Here are two pics showing the Ducktail fitted. ![]()
cycling has-been
I also just got into a 912E this week.
Can any of the contributors here point me to a thread that will outline what's involved with a vented rotor upgrade? Sorry to the OP for the hijack, and thanks for any responses. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
cycling has-been
Brian are either of these yours?
