upwardr's Avatar
rebuilding 912 engine
So I'm getting the parts together for a rebuild on a 69 912 and need some input from others who have been through this.
I have a good block and crank(mag and checked, std std) but I have been confused by the next step of purchasing pistons and cylinders.
Big bore verses std kit, how much of of a difference is there going to be by increasing displacement by this option? Should I consider a warm cam?
When I go forward are there any other modifications that I should consider that would make noticable HP gains.
So the next question is Quality, I have seen Big bore on Samba and Ebay for various prices. NLA offers a set decent price. Any comments on vender vs quality?
I'm not looking to spend big money but I just want a streetable engine with maybe a little punch,
Thanks for any advise
Larry
1971 911T
1983 Envemo, Cabriolet
1989 Carrera Cabriolet
Old 04-28-2009, 08:28 PM
I have just installed Brad's set and they are very good for the price. Warm cams are good but a little jerky for daily driver use. If its a weekender then go for it. Don't forget to re-jet the carb's to match the big bore.
Make sure you check the diff carrier - it seems to struggle with the 100hp and often fails (as I have just found out!)
Old 04-29-2009, 05:49 AM
upwardr's Avatar
Thanks Rols, are you running a mild cam with Solex.
Do you think your car is running about 100 hp?
Any other mods?
Which set of big bore the cast or forged?
thanks
Larry
1971 911T
Old 04-29-2009, 05:47 PM
check out this site...it gives a lot of interesting methods/info for getting the best outta a 356/912 engine http://www.lnengineering.com/356.html have fun!
Old 04-30-2009, 09:51 PM
