GUN
Thumper's Avatar
Head light-turn indicator malfunction ?
My '67 has a problem.........I know this has been discussed ad nauseum
All switch functions work....individually
High / Lo and turn signals, except when I pull the Hi beam flash with lights on
The headlights go out completely....
they also don't flash with lights off.
Relay or Switch ?
any answers....I think it is the relay......and I know if it is I'll have to find a used
old part.
When in doubt gas it....It won't help but it ends the suspense !
Old 07-12-2009, 02:52 PM
My guess would be the high low bypass relay or a short in the switch. Do you have a wire diagram http://www.hillmanimages.com/912/early_912_wiring.html try this maybe you will find it.
Jerry McAbee
1967 912
1968 912
2002 Tundra 4x4
Old 07-12-2009, 09:56 PM
GUN
Thumper's Avatar
Jerry thanx for the input......
I cleaned the switch with contct cleaner no change.
Must be the relay.
Old 07-13-2009, 08:14 AM
Sometimes the contact plates get out of alignment and you can take a little pick and adjust them...
Ken
ks2_motorsports@yahoo.com
Old 07-13-2009, 09:25 AM
