rust removal
what is the best rust removel stuff that you guys have found. I have a 69 912 that has a lot of heavy rust that needs to be removed before I can fix it. I also have heard that after you remove it there is a paint that you can get to seal the metal to keep the rust from returning. Thanks
Old 04-10-2010, 08:08 PM
There are several types of rust killer. There are rust removal types that use acid any automotive store would have ether type. Por15 if still available has a system. It really depends on how bad the rust is. The best way is a wire wheel and a dust mask if you just treat it it's still there just covered up.
Jerry McAbee
1967 912
1968 912
2002 Tundra 4x4
Old 04-10-2010, 09:25 PM
