Christopher E's Avatar
031 Distributor + Ignitor = "jump around - jump around"?
Hi,
I fitted an Ignitor to my 031-distributor and noticed immediately that the ignition is jumping around under my timing light. (say 3-6 degrees?) More so than last summer when I still hade the points. Could this be due to the fact that the pickup and sensor are gapped incorrectly or were my distributor axle a bit worn already and the breaker points were somewhat more "forgiving"?
How does this work?
Thanks,
// Chris (-Kross will make you - JUMP, JUMP!)
Old 04-30-2010, 02:15 AM
You will probably need to have the 031 rebuilt or the least checked.
Old 04-30-2010, 10:29 AM
