'67 torque settings...
hi,
i am still looking for a shop manual for my new '67 912. but in the meantime i would like to change the fluids (if there is still any in there!). i have not much previous experience at this stuff so i am paranoid about stripping threads or important bits falling off the car. ergo, can anyone supply the following info? i got a few manuals, but these kind of details appear to be 'assumed'...
901 tranny - drain plug + fill plug torques. should i use a new gasket for either when servicing? (if there are any)
valves - is there a torque setting for the lock nuts? they took 2 hands to undo, but i only tightened them to about 10+ ftlbs
oil - drain plug torque. new gasket? (present?) oil screen panel screw torque? i gather i replace gasket here each time - ?
the oil drain plug appears to be a filed, mangled, chiselled-at square-ish headed piece of sculpture - i'm assuming this is a non-porsche option...
many thanks in advance,
tim
Old 01-17-2002, 10:46 AM
For all of those, tighten them until they are snug, and you shouldn't have a problem. But, here are the factory torque settings
Oil Drain plug - 18 ft. lbs
And the rest, I wish I had the spec book.
The reason why they were probably assumed is because they don't know them! So no worries and....
keep the 912 faith
Old 01-17-2002, 11:38 AM
Here are some I have from the Maestro's "little spec book"
12mm ATF nuts on 3rd piece of case - 15 ft/lbs
Case perimeter bolts - 15-18 ft/lbs
Connecting rod nuts - 32.6 ft/lbs
Acorn nuts on case - 29 ft/lbs
Cylinder head nuts - 22 ft/lbs
Rocker arm housing - 29-36ft/lbs
Rocker arm to shaft nuts 15-18ft/lbs (might strip nut near 18)
flywheel nut - 324-360 ft/lbs
generator to fan nut - 72 ft/lbs
cam gear bolts - 18ft/lbs
most 8mm (12, 13, 14mm) - 15-18ft/lbs.
This has been a pretty good little book to have handy I highly recommend purchasing it!
I hope this helps........
craign
Old 01-17-2002, 12:31 PM
thanks for the info. now i know what torque 'snugly' is. as it happens i was going to the airport today anyway - i'll check out harry's book while i'm there.
tim
Old 01-18-2002, 10:03 AM
