Accelerator linkage
Help.. something is missing. what I've found i don't understand how it correspond to the picture shown.. Atalanta, pelican and Stoddard. have the same info but still can't seem to connect it..
thank you.. okay can't seem to load photo.. looks like two opposed 1/2" dia washers on a 3/16 shaft one from trans and other gas pedal.. Last edited by lamarque912; 02-22-2011 at 08:51 PM.. Reason: no picture shown |
Accelerator Linkage
From your description, you are talking about the 'throttle link' connection between the rod from the accel bellcrank mounted on the transmission and the metal rod coming back from the accel pedal: there is supposed to be a rubber cylinder adhered to the two 'washers' providing vibration isolation to the accel pedal.
A newer version, p/n 911-423-081-02-M260, is available from our host. The design incorporates a metal enclosure such that when the rubber connection fails, some throttle is still available to get you home. Hope this helps... |
Accelerator Linkage
Peter, thank you.. I'll order this part straight away..
accelerator and clutch linkage updates
Ditto to Peter's comment, to keep from being stranded everyone needs the updated version (which has been out for over 20 years) of the accelerator rod link that incorporates the metal cylinder .
Similarly, make sure the connector from the clutch cable to the tranny fork connection is not plastic; the original design has long since been superceded by a metal connector.
Rick Becker 912 owner since 1977 PCA 912 & 912E Register Advocate, 912 Registry Member #0001 http://912register.pca.org | www.facebook.com/PCA912Register | Twitter: @PCA912Register |
Hey thanks, I'll order the tranny connector as well...
