antenna question
o.k so some jerk off broke my antenna off. any idea how too replace it? iv'e looked around and can't figure it out. do i go through the trunk? through the glove box? i can't find it in my manual anywhere. it is a 1966 912. the antenna is on the passenger side. any help would be appreciated..
antenna
The original antenna on my '66 was on the driver's side, with the cable passing through an opening and under the dashboard. I was under the impression that the passenger side was utilized if the antenna was an optional electric type, since without the gas tank filler assembly on that side, there was a little more room for the motor assembly.
Do many owners have a stock manual antenna on the passenger side?
Rick Becker 912 owner since 1977 PCA 912 & 912E Register Advocate, 912 Registry Member #0001 http://912register.pca.org | www.facebook.com/PCA912Register | Twitter: @PCA912Register Last edited by Rick Becker; 03-22-2011 at 02:03 PM.. |
The standard antenna was on the drivers side so people walking down the street would not reach over and break it off. obviously they were having some problem with people doing this. The Passenger side had the electric antenna. Which is always down with the ignition off. Also as Rick stated there was more room on that side. If the car was for export the radio was not installed until it arrived at the dealers. A lot of radios seem to disappear in-transit. The factory had templates for everything including the antenna placement. If the antenna is on the sidewalk side and not electric. It was probably installed by one of the PO or at one of those car radio stores
thanks i'll nose around some more and see what i can find.
