abit off center
cgarr's Avatar
Paint code 6802 (anyone got the formula)
My car is a 69, Polo Red 6802 code, Sherwin Williams Automotive Finishes has not converted this code for use with their Acrylyd Topcoats yet? Lacquer yes but not the Enamel. Has anyone matched it yet? if not I guess ill spring for the 25 bucks and get it done, inside my gas door is the only original paint left. Any help is always appreciated.
Thanx
Craig
Old 03-11-2002, 12:57 PM
Try Glasurit 22 system. Expensive but worth it. Should be no problem getting the paint right without doing a color match.
Good Luck, JMB
68' 912/5 modified brakes, suspension, limited slip trans, hi-performance engine.
67' 912/5 racecar project
Old 03-11-2002, 09:00 PM
