Smile Nadella shafts
Hello.
I have a '67 912 with the original Nadella shafts. Actually one of them is in very bad condition and I want to know if anyone has replaced this old shafts using the '69 shafts.? Is this coversion possible?
Regards and thanks in advance
Eduardo (Spain)
Old 01-11-2012, 01:27 AM
Max Sluiter
Flieger's Avatar
I would recommend asking here, as that question has been answered there before, I just can't find it.
Early 911S Registry
Or, you can ask "Grady Clay" here on Pelican.
Old 01-11-2012, 09:39 AM
Eduardo,
You can use anything earlier than the '69 axles.
Longer wheelbase and I believe the flange is different.
'67- '68 will fit without problems.
Tony
Old 01-11-2012, 12:37 PM
rebuild versus replace
The old adage was the left would go first, is that the one?
Nadellas were used on 904/906 racecars. Their disadvantage for road cars besides non-constant rotation is the lack of a way to grease the sealed joints. Back in the days of Aase Bros. in Anaheim, CA, they rebuilt Nadellas with new joints that had Zerk fittings. Attached is a scan of an old PCA "Up-Fixin der Porsche" Volume III article with one Nadella rebuild solution. You might consider a similar machine shop rebuild if the Nadella is not too far gone.
Otherwise, you can upgrade to the Lobro style CVs, but will need to change halfshafts, axles, and different flanges on the transaxle.
Rick Becker
912 owner since 1977
PCA 912 & 912E Register Advocate, 912 Registry Member #0001
http://912register.pca.org | www.facebook.com/PCA912Register | Twitter: @PCA912Register
Old 01-11-2012, 01:34 PM
Nadella Shafts
First of all.
Thanks to all the people who are helping me.
I´m in a mess... I would prefer to change the shafts into an Lobro type. But I can´t decide what parts I need to do the job completely.
Is any one able to send me a parts list for the conversion or may be tell me who can send me it?. For information my car is 67 MY and vin number 458368.
Regards
Eduardo
Old 01-12-2012, 01:47 AM
The 2 transaxle side flange for a 67-68 SWB (6 holes each)
The 2 spline flange at the rear wheels for a 67-68 SWB (6 holes each)
2 CV axles
4 CV's (6 holes each)
4 dust boots and clamps
24 Allen bolts (min. tensile strength of 120kp/mm2) and 8 CV type washers.
1 tube of CV type Grease.
Sorry, do not have the part numbers handy. However, make sure that you get the CV's with the Lobro brand name.
Old 01-12-2012, 10:01 AM
While we're on the subject--you can get some inexpensive Empi axles for the 912, but people who have had a lot of experience with them have told me that they are not reliable. Get the Porsche ones, even if you have to get used ones.
Old 01-16-2012, 07:09 PM
I tried the Empi Axles and they only lasted about 500km. The Löbro ones are the only CV to use.
Old 01-17-2012, 09:33 AM
GUN
Thumper's Avatar
2 sources for lobros
I found these 2 sources for lobros
VERTEX AUTO
Porsche Axle Shafts &amp Drivetrain
These are at Auto Parts, Car Parts and Auto Accessories at Discount Prices | DriveWire.com
A1 CARDONE REAR, DRIVER OR PASSENGER SIDE AXLE ASSEMBLY
1967 PORSCHE 912 BASE 4 CYL 1.6LIn Stock .
Zoom A1 CARDONE CONSTANT VELOCITY DRIVE AXLE, REMANUFACTURED -- This high quality and direct fit OE replacement CV drive axle features 100 percent neoprene boots for excellent ozone resistance, 3 percent moly grease for extreme high temperature and pressure characteristics that extend the life of the joint, and 100 percent chased splines and threads that eliminate installation hassle; With A1 Cardone's limited 3-year or 36,000-mile warranty.
See more
Condition: Remanufactured
Quantity Sold: Sold individually
Warranty: 3-year or 36,000-mile A1 Cardone limited warranty
Part #: A1607023
List Price: $88.78 Our Price: $66.82You Save: $21.96 (25%)Core Deposit:$73.20Qty: .Fits the following Porsche 912 submodels
Live Support.1967: All Submodels; All Engines;
REPLACEMENT CHASSIS REAR, DRIVER OR PASSENGER SIDE AXLE ASSEMBLY - OE REPLACEMENT
Zoom CV AXLE ASSEMBLY, NEW -- Includes axle nut, joints, and boots; Manufactured from 100 percent new components to ensure proper fit and operation; Provides maximum safety and stability, restores vehicle's handling and control, and improves passenger comfort over the toughest and roughest driving conditions; Backed by 1-year, unlimited-mileage warranty.
See more
Type: OE replacement
Condition: New
Warranty: 1-year, unlimited-mileage warranty
Part #: REPCVW8058
When in doubt gas it....It won't help but it ends the suspense !
Old 01-17-2012, 09:49 AM
