Functionista
manbridge 74's Avatar
69 912 in Denver.. no engine numbers
Anyone go look at this car? Been on Craigs for awhile so I thought I'd take a look. $9500 ask.
Cons
-a 'ran when parked' car, last run about Y2K
-no engine numbers
-missing vin tag at b pillar?
-will need front pan replaced
-warpy cracky dashy
-left fender replaced but surface rust on non-prepped underside
-can't talk to owner... must go through 'friend'
-no records
Pros
-car seems fairly complete
-car seems solid everywhere else with a paint bubble or two
-orange color, fair repaint
-been stored inside
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 08-20-2012, 08:45 AM
I went to see this car today, brought a battery. He let me disconnect the carbs and turn it over. Engine has compression and seems to turn fine. We rolled the car out of the garage so i could get a better look. Other than the rust on the driverside front pan and surface rust under the rear seats, the car appears to be solid. Not sure why the #'s are missing, are you suspecting anything shady?
Old 08-21-2012, 11:25 PM
Functionista
Robeod, sent you a PM.
Jeff
74 911, #3
Old 08-22-2012, 01:41 AM
