tbonz's Avatar
need info.on type4 swap into'69 912w/4spd.?
Sometimes ya get lucky?
I have a very good chance of getting a '69 912 (project "B") engine less but otherwise great coupe. I am already working on rebuilding my project "A" '69 912 Targa (motor/resto/paint)
which will be down for awhile... so I want to put an economical daily driver together till project "A" can be finished and I can build a spare 912 motor for "B". Opportunity knocks twice and I've located a low mileage 2.0L 914 engine. I need info. on type 4 swap into '69 912 w/ 4 spd.? I've heard of it.... but never seen one installed. I understand I would need to fab.. a front motor mount rail? or does the 1976e motor rail swap into the 1969 motor mount location? Is there any clutch and flywheel issues? The type 4 engine has dual webers so that the stock throttle cable will work but it might have to be shortened or made longer (no sweat) and the cross bar carb linkage needs to be flipped or moved right or left to be in alignment (it's a 914 2.0L engine) hex bar linkage does that too....The electrical hook-up seems to cross over with no issues except checking to see if existing 912 regltr.can handle the alternator or does the 914 alternator have an internal regulator? That's easy too. Also I'll have to find a 1976e header/muffler system. right? It will fit probably. Otherwise...I'm asking you all...(hey!... I'm from south of LA.O.K!) I'm saying it looks do-able right? Anybody with info or knows someone who has a conversion that is running that I could look at...please ask them to post the info.or/ pass on the particulars to my email address. ...this could almost solve my "912 jones" and I'll "A""B" in eternal gratitude to anybody who can help! So... here's wishing you (all) a ticket less good karma for your time!... thanks!
Tbonz
Old 06-19-2002, 06:57 PM
912s's Avatar
Besides searching thru previous posts here you can also look at Good luck.
Scot
'67 912
'69 Bug
Old 06-19-2002, 07:50 PM
tbonz's Avatar
thanks for the link! I just glance at it and it looks like a gold mine!....tbonz
Old 06-20-2002, 01:51 PM
Senior Member
Hello
The 912 E has a other engine carrierer and other mounting points.
If you search trough this board you will find some usefull posts.
Also shoptalk has some posts about that subject.
Grüsse
Old 06-20-2002, 02:29 PM
tbonz's Avatar
thanks for reply you guys
I am going to dig into some site searches tonight for hopefully some detailed "bolt by bolt" accounts of how just average guys become driven trying to re-create a clone from bits and pieces of differnent german DOA's ...an unholy wedding! isn't one freak.... isn't enough! No they feel the need...the need to apply jumper cables to...a "Son Of '76E.EEEEEEEEEEk!" igor! quick..bring the metrics... we are off to the boneyard!... but luck has it we won't need a BRAIN ....we will go with the carbs instead! Then we will see what goes (or if it will?)or if it's possible! ..But if it does... you know when... when it LIVES! (look for a mob of Registry Guys with torches) you can't stop me now! you know what I mean?
later.....tbonz
Old 06-21-2002, 07:44 PM
willbur's Avatar
Tbonz,
Post your results whatever you find I am curious about this swap. I have already masterd the the type 1 VW into Porsche swap 2110 dual DELLS center mount 911 fan etc... You can always go LARGE up to 3.0 with a type V...
Wil D
______________________
47 Plymouth P-15 / 55 Willys 6-226 / 64 Dodge Dart / 65 Porsche 9series / 68 Porsche 9series / 69 Dodge Charger /67 VW SoCal look
Old 06-21-2002, 10:50 PM
Efrain68912's Avatar
For an engine mount, you can use a bus mount with drop links. Since you're from LA, you should come join us. socal912.org.
Efrain
68 912 Coupe
62 A-H Sprite (VARA DP)
97 Van Diemen FC
94 Mazda RX-7
Old 06-21-2002, 11:27 PM
COLDBASS's Avatar
Thumbs up
Tbonz,
You may get lucky and be able to fab something from a 914 exhaust.
The factory 912E exhausts are rare...I have never seen one...the majority of us 76ers just run a Bursch (the only off the shelf option available). Chris Foley with Tangerine racing makes a complete header system for a 912E. I asked and unfortunately Chris does not fab anything else for a 912E.
I will probably "store" the Bursch and go with a SS custom unit later this summer . Craig with FAT performance referred me to a local SS exhaust specialist. It kills me that there aren't any other options for this model.
Good Luck, Hope this helps...
Bob
Old 06-23-2002, 02:02 PM
Senior Member
Hello
The factory exhaust system ( type 923 ) nas the same exhaust flange like the 914 2,0.
Best is you llok for bus 411/412 heat exchangers. There are big and thin exchangers :the big ones for the bus are heavy.
Then you can fit any type 4 exhaust and if you use bus you can selct right or left side exhaust tip.
Best is a aftermarked sport muffler like the Supersprint and prolong the exhaust tube.
Grüsse
Old 06-24-2002, 09:15 AM
