C. Clark's Avatar
Porsche Crest pointless ignition
Hello,
Does anyone know if a Pertronix pointless ignition system, be used in conjunction with a permatune CDI setup?
Thank you,
Chas. 69/912
Old 06-29-2002, 06:51 AM
C. Clark's Avatar
Porsche Crest reply
Hello,
Since I recieved no relpies I'm assuming no one knew the answer. I e-mailed Perma-tune and was advised as follows...
"Yes, you can use the Pertronix. Connect the red wire of the Pertronix to the
violet wire of the 911e box and the black wire of the Pertronix to the
yellow wire of the Perma-Tune."
Set the ignition timing to stock specs.
Old 07-01-2002, 04:34 PM
