Porsche Crest installing a 2.4 911 motor into a 66 912
Aside from changing motor mounts and installing an external
oil tank, can a 911 2.4 motor be installed in a 66 912 and
mate to a 901 transaxle without too much hassle.
Old 07-03-2002, 11:47 PM
Ads912's Avatar
There are a few guys here who have done it.
You will need a clutch and pressure plate from a 65 - 69 2.0L motor, a 911 tachometer, a 912 temp sensor on your 911 motor, modify your throttle linkage, if you have an MFI or CIS 2.4 motor, you will need a return fuel line to your tank (if the 2.4 has carbs, you are fine).
The steel motor mounts are available from Porsche.
Adam White
Current: 1971 Alfa Romeo GT1300JR
Gone but not forgotten:68 912, 76 911S, 72 911T, 1983 Audi UR Quattro
Old 07-04-2002, 06:45 PM
Senior Member
Hello
You need the 911 2,0 flywheel & clutch.
You have to make a interface for the electric wireloom from the engine or remove the enginewireloom
Grüsse
Old 07-05-2002, 02:45 AM
Great, thanks for the help
Old 07-05-2002, 09:29 AM
