I am doing some rust repair on my 69 912 and need someone to email me a picture of the area that keeps the washer bottle in place. I am told that there is a metal lip that it slips behind. Any help would be appreciated since there was nothing located on my replacement suspension pan.
thanks dave |
Dave,
I can send you a picture later today when I get home. Craig 69-912 |
69 912 washer bottle mount
I am having the same problem trying to mount the washer bottler for 69 912. Anyone have a picture?
Thanks |
Guest
Posts: n/a
In the following thread here on the board, the washer system including the bracket is explained with pictures.
1970 Window Washer System I hope this is what you need. Otto |
Guest
Posts: n/a
I remembered I had a picture of the bracket/support for the water tank. Here it is:
![]() Quite easy to make from a piece of sheet metal. To attach it to the car you could spot weld, screw or rivet it to the floor panel of the trunk. The original one is welded to the car, if I remember well. Otto |
