abit off center
Another rear swaybar question?
Ok you guys, im getting real close the getting this thing installed. I put the adapter kit in on the torsion bar tube since I never had a swaybar on the car but the swaybar hits the front transmission mount, my mount has the two large square rubbers just like the engine does, do I need a different transmission mount to make it clear or should I have my local spring shop bend me up a bar to fit around it? Now, I am using a stock factory swaybar but purchased the insstlling kit thinking it would work, should it?
Thanks Craig |
Find yourself a junkyard early 911 trans mount. It will bolt up and has the clearance you need for the bar.
