Does anyone know if you can replace a rear wheel lug without removing the wheel hub on a 69?
Is there enough room to press out the old lug and press in a new one into the wheel hub? I need to replace one right rear wheel lug. Any special tools needed? I think my screw press tie rod remover will press it out. Thanks, Ron D
RonD 69912T |
Hello,I can't answer your question,because I'm at work,but lets just say you"could". I would be very careful as to how you would remove it,in other words ,don't pound on it ,press it out with a smaller bolt from the rim side and a C-clamp and a deep socket on the other side to recieve the broken stud
Just might work
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
Steve:
That's a good idea if there is enough room in back of the lug somewhere aroung the hub rotation path. Thanks, Ron
RonD 69912T |
