abit off center
cgarr's Avatar
Is this where the oil plug is installed?
Is this where they plug the oil pump outlet when changing to a full flow filtering system? Is the hole just tapped and plugged? What size pipe tap is used?
Craig
Old 10-23-2002, 03:24 PM
Senior Member
Hello
Yep thats it. AFIR use a DIN 910 plug size was 14 x1,5 or 16 x 1,5.
You have to drill up and off center.
Grüsse
Old 10-25-2002, 05:34 PM
