Compression test question for potential 912 purchase
I'm looking at a car that has the following compression numbers:
1) 145psi 2)140psi 3)120psi and 4) 150psi
#3 is 10% lower than the others. Is this a problem?
I was told this could be the potential problem-
"The cooling air to #3cylinder is blocked by the oil cooler so it tends to run hotter and as a result it tends to wear faster than the other cylinders."
Any help is much appreciated.
Old 04-12-2015, 10:00 AM
