Touque's Avatar
fried my distributor???
yikes - I was playing around (i.e. tweaking ) with my timing today.
I had my timing gun hooked up, and also a Craftsman Engine analyzer to see what my rpm's were. Both the timing light and analyzer were hooked up to the coil. I went to turn my distributor and must have shorted something out because my motor just stopped (I think I grabbed a couple of plug wires at the same time), and I saw smoke coming out of my new 050 distributor! Popped off the cap and the little 'wire' was very black and crisp like it just had a bunch of volts go thru it.
Anyone know what I did and what I need to buy to get it up and running again. Luckly I had my old 009 and although it works, i'd like to go back to the 050.
I just cant leave things well alone... should know better by now
Old 11-25-2002, 12:54 PM
I think the only wires in an unmodified distributor would be the wires coming from the condenser. That would be the only item to replace. If the points are burned then you should replace them too. Points should be shiny and smooth. The 050 points and condenser are inexpensive VW parts (good thing).
Jones Low
69-912
00-Box
Old 11-25-2002, 02:43 PM
