912E #444
racerpaul's Avatar
Send a message via Skype™ to racerpaul
Distributor causing idle problems? Advice needed
My wrench guy says the vacuum on my distributor is causing idle problems. Recommends the Hot Shot electronic rebuild.
Any advice?
Paul
912E Stock Einspritz Fuel Injection
912E #444 Former Formula 2000 / Formula Ford piloto.
"Butzi"
http://forums.pelicanparts.com/porsche-912-technical-forum/397159-912e-newbie-how-am-i-doin.html
Old 12-29-2015, 06:20 AM
WFBowen's Avatar
Paul:
He may be right, especially if your 912E is still running its original dual vacuum distributor which relies on "below throttle" vacuum source to pull the plate back to the idle position.
There seems to be an ongoing discussion about whether both or just one vacuum source is used on the 912E dist. I have owned 2 of these cars - one had the advance side blocked, the other used both so it's a draw from my experience. And, I have yet to see a concise factory schematic - others are on the net but don't always make sense. Either way, following the specific timing procedure is critical (AFAIK you can't static-time these cars.)
Bill
Old 12-29-2015, 03:03 PM
912E #444
racerpaul's Avatar
Originally Posted by WFBowen View Post
Paul:
Bill
Thanks Bill for the reply. I guess I will be looking for a new distributor. Or a rebuild. Any ideas where to look?
"Butzi"
Old 12-29-2015, 03:56 PM
912E #444
racerpaul's Avatar
Got a tip that this refurbished might work...
http://frugalmechanic.com/auto-part/cardone-31915-distributor?p=frugalmechanic_google&gclid=CMihxMu_i8oCFc2RHwodBloIYg
Any ideas?
It's also available at autozone
"Butzi"
Old 01-02-2016, 07:55 AM
