912E #163
912E fuse identity
Hi I just picked up #163. I am looking for help indentifying the fuses up front. I did some searching but can't seem to find o good diagram. Thanks for any help offered. Keith.
Old 09-14-2017, 03:12 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hi Keith and welcome to the forum! I'm attaching a link to an earlier thread where there is a good diagram of the fuses - I hope you find it helpful.
1968 fuse panel assignment
Old 09-14-2017, 11:50 AM
WFBowen's Avatar
Keith:
If it's a 912E then these might help:
(Nice car BTW)
Bill
Old 09-14-2017, 02:10 PM
912E #163
Thanks, it's a 912E. I forgot I had the owners manual, same page as WFBowen. Mine is a 912E and only has 18 fuses the manual shows 21. May have to get the meter out and start flipping switches.
Is there suppose to be a cover that may have the fuses listed on It? A photo of that may help me.
Old 09-14-2017, 02:52 PM
The cover has labeling for each fuse on the inside. You can order a new one with part number 91161216101
I went through the wiring diagram in the workshop manual for the 912E and this is what I've come up with:
From front to back:
Fuse 1: none (for fog lights)
Fuse 2: (yellow, 5A) rear licence plate lights
Fuse 3: (yellow, 5A) front and rear parking lamps, right
Fuse 4: (yellow, 5A) front and rear parking lamps, left
Fuse 5: (white, 8A) low beam, right
Fuse 6: (white, 8A) low beam, left
Fuse 7: (white, 8A) high beam, right
Fuse 8: (white, 8A) high beam, left; high beam indicator light
Fuse 9: (yellow, 5A) front turn signal, right
Fuse 10: (yellow, 5A) front turn signal, left
Fuse 11: (red, 16A) brake lights, flasher relay, back up lights
Fuse 12: (blue, 25A) rear defogger relay, rear defogger indicator light, fresh air blower
Fuse 13: (blue, 25A) windshield wiper motor, windshield washer pump
Fuse 14: (red, 16A) electric sunroof if installed, otherwise none
Fuse 15: (red, 16A) cigarette lighter, light for blower motor switch
Fuse 16: none (for power windows)
Fuse 17: (red, 16A) emergency flasher
Fuse 18: (yellow, 5A) interior lights, clock
So pretty much the same as the owners manual except the 912E doesn't have headlight washers, factory AC or a fuse for the fuel pump.
Old 09-14-2017, 07:48 PM
912E #163
Thank you. As a new Porsche 912E owner I find other owners are very friendly and helpful. I look forward to meeting another 912E owner to compare cars, I briefly met someone close by me in CT before I tool ownership if this one.
Old 09-15-2017, 02:50 AM
912E #444
racerpaul's Avatar
Send a message via Skype™ to racerpaul
Welcome to the legion of 912E owners here on the forum!
Any questions will be enthusiastically addressed here as you have seen.
Groton huh? Home of some of our nukies! I was stationed at the Coast Guard Academy and the Eagle back in the day... don't ask how long ago...lol
Check out my threads and give a shout,
Paul
912E #444 Former Formula 2000 / Formula Ford piloto.
"Butzi"
http://forums.pelicanparts.com/porsche-912-technical-forum/397159-912e-newbie-how-am-i-doin.html
Old 09-16-2017, 06:26 PM
