AirBorne!
Gearbox Confirmation Question
I'm near here, but have been on the 944 and 911 boards for years. I have a 1967 barn find 912. Irish Green and she can be saved.
The engine is gone - a V8 is roughly bolted into the rear now -- but the gearbox is there along with a so so interior, but with rust crude on all the panels.
Could someone please confirm the following regarding the gearbox:
The stamped number on the case nose is 234689. That would make it the five year unit with gears, A, F, M, S, X and a 7:31 r/p, correct?. The car's serial number has it built late in the Karman model run in 1966 even though it's titled as a 67 and the serial number matches it.
Also, on the case the following casting marks are show:
26/66, that I assume is for 26 week in 1966?
And i have no idea what this mark means:
901.901.101.0R
Given that the prior owner put in a V8, what's the story on the case?
Any ideas?
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed
Old 11-25-2016, 12:13 PM
If it is a 5 speed there should be a 902/1 on the case. If it is a 4 speed then there will be a 902/0 on the case.
Old 11-25-2016, 12:49 PM
WFBowen's Avatar
That 901.xxx.xxx.0R is a trans case casting number. Cars produced After Aug 66 would be 1967 model year cars. And you're correct that the trans serial # corresponds to that
5sp with the gear set you mention.
Bill
Old 11-25-2016, 09:20 PM
AirBorne!
Thanks Bill.
Old 11-26-2016, 05:47 AM
djpateman's Avatar
That serial series for the 1967 912 started with 234001, so it is a fairly early 1967 912.
Bill is correct about the case casting #. You are correct about the casting date and gears. The casting date is often a few months before the transmission is installed in a car. What is the VIN?
I would not use that transmission with a V8.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 11-27-2016, 03:57 PM
AirBorne!
Trust me the V8 is coming out and I hope the PO didnt ruin the gearbox with it.
Old 12-17-2016, 01:32 PM
