abit off center
Cadnium Plating
Does anyone know of a good place that will process a small run (bag of nuts and bolts) cadnium plating?
Thanks Craig |
doesn't eastwood have a do it at home cad plater??? or is that zinc??
plating places are dime a dozen in Livonia...let me do some looking. where in MI are you?? I was in Ann Arbor, but worked just outside of detroit. sjd used to work at Roush.
Porsche sold, moving back to muscle cars for a bit. Last edited by atlporsche; 01-16-2003 at 04:13 AM.. |
abit off center
I am in Grand Rapids, I know there are a ton over by Detroit but who would do a hand full of parts?
Thanks Craig
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
You might get in touch with John Twist at University Motors in Ada. John's business is British car repair and restoration, but I suspect he'd know about sources for cad plating in the Grand Rapids area.
finally got the list...give these guys a shot if you haven't found anything.
Ductile Chrome Process Ph. 734-261-8310 Fax. 734-261-9490 Fini Finish Metal Finishing Ph. 810-578-0050 Fax. 810-578-0054 International Hard Coating Ph. 313-535-7210 Fax. 313-535-3220 Bellville Plating Ph. 734-697-7000 Fax. 734-697-7023 McNichols Plating Ph. 313-538-3470 Fax. 313-538-0025 Pioneer Metal Finishing Ph. 734-384-9000 Fax. 734-384-9577 Alpha Metals Ph. 734-426-2855 Fax. 734-426-2954 Associated Electro Platers Ph. 248-547-5520 Fax. 248-547-5521 B & L Plating Ph. 810-778-9300 Fax. 810-773-4366 Dependable Hard Chrome Ph. 248-474-6656 Fax. 248-474-0489
Porsche sold, moving back to muscle cars for a bit. |
