Newbie here, starting issue
Bought a 76 914 2.0 fuel injected. Car sat for several years. Just replaced the spark plugs, wires, cap/rotor, new battery, and cylinder head temp sensor. The car has started only 3 or 4 times, only when depressing the accelerator fully.
Now, the car will not start. Cold start valve has fuel sweating from the fitting. By the way, I tested the CSV, showing almost 5 ohms.
Got a sweet deal, got a 73 911 2.4 cis engine with the car.
Old 10-08-2018, 01:37 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello and welcome to the forum! You've come to the right place - this forum is filled with a ton of info from some very knowledgeable people. Take a look at the link below to a DIY tech article from our site, hope this might help you with the starting issue. Please let us know if you have any questions.
https://www.pelicanparts.com/techarticles/914_ignition_switch/914_ignition_switch.htm
Old 10-08-2018, 10:11 AM
914 Geek
First, I would suggest removing the fuel line from the CSV. It should only be opening while the starter is cranking, and only when the engine is below ~32F or 40F, depending on which source you believe. You can cap the fitting that the fuel line comes from with an appropriate bolt, or put a bolt and clamps on the end that used to plug into the CSV. Or you can plumb a fuel pressure gauge into that line, which is what I did. Handy to have a reference available any time I want to look....
I would not be as quick as Dmitry seems to be to blame the ignition switch, though it certainly is one of many possible causes.
A first check would be to inspect all hoses and wires, making sure that nothing leaks and everything is not brittle, the connections are solid, and that it all connects to the right places. The various components can then be tested to make sure the values appear to be reasonable. The website at http://members.rennlist.com/pbanders has collected pretty much everything that is currently known about D-Jetronic EFI, and is an excellent reference.
--DD
Old 10-08-2018, 01:28 PM
Thanks, will try capping off the line. Will keep you posted. You guys are a big help. Awesome forum��
Old 10-08-2018, 04:58 PM
Maybe a few basic checks should be done first?
Does the fuel pump run when you turn on the key? Do you have fuel pressure?
Do you have spark at all cylinders? Are the spark plug wires attached correctly?
Ignition timing when cranking the engine over?
Old 10-08-2018, 09:53 PM
