-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Removable Backpad to Access Engine (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/101686-removable-backpad-access-engine.html)
D7N7MASTER 03-17-2003 07:39 PM
With that engine - Wouldn't it just suck U into the trunk? I'd hate to have that problem. he he he... Better give it to me. But on a side note; has there been structural considerations - prior to cutting a hole?
Gary
'73 914-4 2.0 f.i. (wannaba6)
Andyrew 03-17-2003 07:47 PM
Lee, a thought just occured to me, isnt it very loud in the Passangers compartment? a there is a Big opening from the 6' engine to the cabin? I think that putting a piece of aluminum over that hole with bolts (?) holding it in is a smart thing douglas. Looks good both of you.
Potter 03-17-2003 09:42 PM
The "Bat-door" into the engine compartment is a very interesting idea......and one that reduces the amount of time a guy spends with the rump facing the sky and legs knifed into the air like a Praying Mantis.......but one phrase has me concerned: "Cut a hole in the FIRE wall"
http://forums.pelicanparts.com/uploads/FIRE.GIF http://forums.pelicanparts.com/uploads/fire2.GIF
"Is it getting warm in here or is it just me???"
Potter 03-17-2003 09:43 PM
By the way......I have tons of even better pictures in the screensaver...............
Andyrew 03-18-2003 07:36 AM
I want that screan saver now, lol
Dave at Pelican Parts 03-18-2003 08:38 AM
Yup. As I once said to Michel Richard, "Think about the name of that panel. Firewall."
I suggest getting that metal panel in there ASAFP. A little sound-deadening stuff on the inside of it probably wouldn't hurt, either...
--DD
Mountain914 03-18-2003 10:04 AM
Yeah - it's loud... but sweet, sweet music to my ears!
Actually it's not that bad with the cushion velcro'd on. If you heard my exhaust, you would know it's just as loud with the windows down and top off. The 3.0L runs smooth as a kitten (when warm) and very little noise, other than road noise, is noticable.
OK, OK - I know what a firewall is for! :p (hee hee)
I have decided to go with aluminum (cost and ease) and am shopping around for some kind of dzus fasteners this spring. Should have stated 'save the safety speeches' in my post (grin)!
Right now - got about 4 feet of snow outside, so I'm going nowhere!
Bruce Allert 03-18-2003 01:05 PM
I found having the car on ramps, chock both front tires and jacking the drivers wheel up just high enough to get a jack stand under it does the trick for adjusting the valves. It's high for working on, easy to spin the tire with your foot for the right side valves whilst under the car... no problem-o:)
bruce
rich 03-19-2003 08:01 PM
How about this removable panel?http://forums.pelicanparts.com/uploa...h firewall.jpg
bander 03-20-2003 05:23 AM
To hold the rear wheel durring a valve adjustment, I just use a rope to tie one spoke to the strut. That wood cross lookd likje the frame that I bolt to my jack pad when I remove the engine
Potter 03-20-2003 07:19 AM
I sure hope you guys keep a bag of marshmellows in the glove compartment.......would be a shame to waste a perfectly good opportunity for a s'more party..........
