dc914guy's Avatar
Send a message via AIM to dc914guy
Throttle Body Gasket?
I pulled the throttle body off of my engine today to continue the cleaning process, and I noticed that there was no gasket between the throttle body and the top of the engine. Is this normal??
Thanks,
~Eric
Eric Devansky
986s - Radio Flyer
20% of a 951 parts car remains
Old 03-26-2003, 08:51 AM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Should be a gasket there between the TB and the plenum. Make one using the TB as a pattern out of gasket material from FLAPS.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 03-26-2003, 10:32 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
In a pinch, you can even use the cardboard from a 6-pack of beer.
Old 03-26-2003, 10:37 AM
3D914's Avatar
Eric,
Geoff is correct. I used the same method when reinstalling my throttle body on an new plenum box, and it works just fine. Of course you may prefer the 6-pack method - just depends on how clearly you want to see when cutting! (Hehe)
Gerard
74-914 White - Soon to be a custom 3.2L Six 87-924S 2.5L Artic White - SOLD 74-914 2.0L Ravenna Green - SOLD
Old 03-26-2003, 10:51 AM
Might want to check again
Hey. you might want to check again. I pulled the throtle body on my '73 2.0 and thought the gasket was missing. Closer inspection showed that the 30 year old gasket had turned the same color and almost the same consistency as the Plenum. I had to scrape it off with a razor blade.
Old 03-26-2003, 01:41 PM
914 Geek
Yup, that's exactly what I found on my car. Except that I went and installed a gasket, causing a really massive vacuum leak. Then I went back in and checked more carefully...
--DD
Old 03-26-2003, 02:23 PM
Bleyseng's Avatar
To do it right, scrape the old hard gasket off the TB and use sand paper (#320) on a piece of glass. Sand the bottom of the TB flat then put it backon with the new gasket. I like a litttle sealer on both sides of the gasket. Won't leak abit!
Geoff
www.914Club.com
My Gallery Page
Old 03-26-2003, 04:23 PM
