P Car Addict
klober23's Avatar
1970 Fog Light Install / Mounting - No Mounting holes
Hey folks. I have a 1970 914. The COA has fog lights listed as an option that came on the car, there is a fog light switch in the factory position inside the car, and the wiring of course is present where the fog lights mount. I have worked on many 914's but they have always had the fog light clearly bolted in what I would call the normal mounting position (square extruded section with the built in threads).
This car has no threaded holes in the normal position to mount the fog lights (or anywhere else that makes any sense). The horn brackets and holes are present, but nothing for the fog lights. Was there an alternative factory method? Early method? I am at a loss of how to mount these correctly.
Thanks in advance.
RIP Grady Clay
Old 11-24-2019, 03:44 PM
racer's Avatar
Any evidence of front end accident? maybe when repaired it was filled in? replacement panel?
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 11-26-2019, 04:44 AM
dr914 ***********
maybe a replacement front panel from a 75 76 model
Old 11-29-2019, 12:30 PM
