Help needed 914 gearbox mixed the fork balls
Hello everybody. I was pulling apart my 914 gearbox because the main shaft bearing at the intermediate plate got destroyed . While I removed the stacks from the intermediate plate the bearing fell into pieces , as did the spring loaded bals for the forks . Of course I can’t understand which ones are the fork balls and which are from the bearing .
Old 03-30-2020, 01:30 PM
Those intermediate ball bearings measure 0.315 in. In diameter. If you measure the peanut shaped ball in the shift fork assembly that diameter will be the same as the ball bearing (spherical) in the shift fork.
Old 03-30-2020, 07:24 PM
