sjhenry1075's Avatar
Turn signal issue
Going through my car trying to get it ready for inspection. Had no emergency flashers or turn signals, had a spare flasher so I replaced it. Flashers & turn signals worked except right rear. I pulled the bulb, which was fine, (so I put it back in) but now I have flashers but no turn signals. Could this be a ground issue? Flasher switch?
Thanks for any insight..
Old 04-11-2020, 07:36 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Double-check the connections on the turn signal housing. Also double-check that the bulbs are the correct type; single-filament in the sockets with one terminal in the bottom, dual-filament in the sockets with two.
From Jeff Bowlsby's amazing 914 Tech Notebook website:
--DD
Old 04-11-2020, 11:25 PM
Thank you, I’ll check those
Old 04-12-2020, 05:35 AM
