correct tire pressure
what is the popular consensus on tire pressure (lbs) for "normal" driving on 195/65/15 tires on the street?
In the shop at Pelican
I used to always run around 30 PSI in each tire. However this is something that varies from tire to tire.
Administrator
Stock spec is 26 PSI front, 29 PSI rear.
I run 32 PSI all around, or sometimes pump up to 36 PSI for autoX on street tires. It definitely makes the ride firmer! 30 seems to be a good compromise between the response of the car and still being able to keep your kidneys. ![]() --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Dave, what size tire are you running at AX?
bruce
Sit'n here Hav'n a beer. Punkin's gone (sniff) Gotta mow the Lawn... |
And also, do you think it matters if it is a 50 or 60 series for AX?
bruce
Administrator
For autoX, the shorter the better. I have run 195/50-15. Short-short-short sidewalls, which is good for gearing and handling and responsiveness, and makes for kind of a sucky daily driver. High freeway RPMs and a harsh ride...
I'll probably go 205/50-15 when I get separate race tires; that is the "default" size for 914s in PCA Zone 7 at the moment. --DD
I'm already there with the 205's. Got a good deal on Nittos and they seem to be fairly sticky. With the new motor mounts in I'll be ready for the May 4th AX. Now I just need to get that Orange helmet!!! bruce
