kellzey's Avatar
Conversion Project Update!
After a 3-month hiatus, I am in the project mode again. I spent the last two days feverently working on stripping the car.
Updated pictures are at my sight
http://www.iepg.com/914
I've also got some updates on items for sale.
Hopefully I will be ready for the body shop in 2-3 weeks. I am almost done stripping the car. All I have left to to is finish the front gas tank area, POR-15 the floor pans and rear firewall. Remove the driver's side rocker panel, and drill the holes for the passenger side mirror.
I started working with my Porsche mechanic on the motor again. We should start assembly the block in the next 2 weeks.
Here's the plan...
3.0L shortblock with upgrade 3.6L oil pump and sump plate.
Early SC single-plug cylinder heads with the larger intake ports
98mm J&E Pistons & Cylinders (9.5:1 CR) (This will effectively make it a 3.2L short stroke)
Elgin Modified S cams
Weber 46mm IDA carbs
Electomotive distributorless Igition
Kennedy Engeering 9" Stage-2 Clutch Package
Headers
Custom Exhaust
Basically 260HP+
Regards,
Qarl
Old 04-19-2003, 10:03 PM
toman's Avatar
I really like the look of that exhaust setup on your site, with the dual mufflers. Got any pics or links with pics of complete cars like that?
Old 04-19-2003, 11:18 PM
korijo's Avatar
Nice!!
Been waitin' fer the update
Dave
Korijo
73 Olympic Blue 914 1.7L (2L /4 back in progress)
69 Highlander Bug 1776
93 GL EV 2.8L The Van ™
914club.com Member #914
Old 04-20-2003, 12:23 AM
Jim Smolka's Avatar
According to BA's book, the 3.6 oil pump has more capacity than a previous 911 oil pumps. IMHO, you may need to run AN 16 lines to your cooler as compared to the AN 12 you can on a 2.0 - 3.2 motor's oil pump.
Great project!
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 04-20-2003, 05:44 AM
kellzey's Avatar
http://www.patrickmotorsports.com/cgi-bin/main?action=gallery&id=10
Try here for a car from Patrick Motorsports with this type of exhaust.
Schweet!
Qarl
Old 04-20-2003, 08:41 AM
toman's Avatar
Anybody heard what it sounds like? Also, wouldn't it be pretty heavy compared to stock? Looks killer though...
Old 04-25-2003, 08:55 PM
kellzey's Avatar
Talk to Buck in this thread...
look what I got back from the shop!
He has a set. Not sure if his car is running or not.
Regards,
Qarl
Old 04-25-2003, 09:00 PM
scg scg is offline
scg's Avatar
Dang! That thing is going to be a work of art when you're done...I love it!
...I bet your son can hardly wait to borrow it for the prom
Scott
74 914-6 2.7
Old 04-26-2003, 09:46 AM
