tat2dphreak's Avatar
another dumb question
I recently changed my oil and adjusted the valves on my '72 1.7..
when I checked the oil the level was fine so I started it up, drove for a while and checked for leaks... no leaks were found. however, I checked the oil again the next morning and it was Very low, barely touching the dipstick! still no leaks, though. I added about 3/4 of a quart... now I check it and it's too much oil!!! (the level is almost 1/4" above the fill line).
1.) what did I do wrong?
2.) what caused this?
3.) is this overage enough to worry about/should I drain some out now?
4.) should the oil only be checked when the engine is warm and running?
PS - don't laugh at me.
'72, now with a living, breathing 2056...
Old 04-22-2003, 09:25 AM
AZ914's Avatar
Keep in mind that I am no mechanic:
If you checked the oil before starting, the filter probably hadn't filled up yet.
Jason (AZ914)
75 Malaga Red 914/6 3.2
Old 04-22-2003, 10:03 AM
jamcleod's Avatar
Send a message via AIM to jamcleod
in fact, you can fill up the oil filter (almost full) before you screw it on and you won't run the engine with no oil pressure
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 04-22-2003, 10:32 AM
yes, drain a little out. the dipstick is a just a pint between add and full.
next time. pull the plug. drain the oil. take the plate off and clean the screen ( nobody does this anymore. have new gaskets as required ) reinstall the plate and plug. pour 3 quarts in the motor. remove the old filter. pour fresh oil in the new filter and let it sit for a minute for the paper to suck up some oil. pour a little more in the filter, lube the o ring and spin it on.
start the motor and check for leaks. let it run untill the oil gets warm. shut it off and let it sit for at least 20 minutes on LEVEL ground. then check the dipstick with the engine off. always keep it at the full mark.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 04-22-2003, 10:48 AM
I did fill up thhe oil filter... most of the way anyway, I guess I'm more concerned now that it is showing over... will this do any damage?
Old 04-22-2003, 11:07 AM
anthony's Avatar
1/4" above the fill line is nothing. Autocrossers routinely run these engines with extra oil to prevent starvation around corners. Just drive it.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 04-22-2003, 11:37 AM
coo
I'm just paranoid... I have friends who have told be stories of blown front seals from a 1/2 qt. extra in a type 1 and didn't want to do that to my '14.
thanks for the help
Old 04-22-2003, 11:48 AM
Rouser's Avatar
Send a message via ICQ to Rouser Send a message via AIM to Rouser
Post
The one thing I quickly noticed when I OOPS'd it over the full mark was that the excess oil began weeping out of the front crank seal during operation, rating an Exlax Moment of 8.
I drained the difference out and set it to the proper level; leak stop immediately.
Rouser!
Old 04-22-2003, 11:55 AM
if there's only 1pt between add and full I am probably 1 pt. over. I have been looking for leaks and looking to see if the level drops any in between uses....so far no leaks, and no change in level. I may drain a bit out this weekend, unless you think 1 pt. too much is nothing to worry about.... what do you think?
Old 04-22-2003, 12:08 PM
i have always heard a half quart over is okay on a type IV.
Old 04-22-2003, 12:22 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
I run 1 pint over; it helps keep the oil light off a tiny bit longer in the sweeping turns. No problems from it that I can tell. It seems to be generally-recommended procedure in 914s.
--DD
Old 04-22-2003, 02:08 PM
cool guys, thanks for the info, I guess I'm just paranoid. I've been driving it like that, but then a friend said that over is bad on type 1s so I got scared.
thanks for the info!
Old 04-22-2003, 03:17 PM
Potter's Avatar
Send a message via AIM to Potter
You mean we have to change the oil in these things????
'73 914 2.0
"Seriously Honey, the part was really really cheap...........honestly"
Old 04-22-2003, 04:29 PM
hay i just thought it was meant to leak out so you just add more every so ofen and change the filter
scott thacher
75 914 with 2.5 l 98 suby engine on the road
Old 04-22-2003, 06:57 PM
M. Hendrix's Avatar
If we could figure out a way to aim vaccum leaks..
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 04-22-2003, 07:26 PM
Potter's Avatar
Hendrix.......you absolutely KILL me..........I love it. Something tells me that the humor is not recognized by everyone..........but man, I recognize it and I really do appreciate it. Obtuse humor makes my day.......keep it up!!!!
'73 914 2.0
Old 04-22-2003, 09:40 PM
mikester's Avatar
Send a message via AIM to mikester
I hear that if it isn't leaking it means you're out of oil...
Of course, mine doesn't leak...and I'm not out.
-The Mikester
I heart Boobies
Old 04-23-2003, 03:31 AM
A lousy pint over? Mine burns that up in 50 miles.
Neal
Old 04-24-2003, 05:24 PM
csooc. constant state of oil change.
kevin
Old 04-24-2003, 07:18 PM
