Hell hole rust
Hi
I have a 74 914 2.0. Orig 110,000 miles. Previous owner spent 10K for a repaint. He didn’t address engine bay. Battery tray rusted and “surface rust” under and around. Any good shops to address hell hole? Thanks
I’m in Los Angeles
Old 03-08-2021, 11:06 AM
RETIRED
Joe Bob's Avatar
You will need someone with a Cellette Bench. It’s a suspension part. Not something to guess at yet.
Old 03-09-2021, 08:24 AM
Could get really ugly really quick. How do your doors operate and how do the door gaps look
Old 03-12-2021, 03:51 PM
Doors are fine
Old 03-12-2021, 07:06 PM
RETIRED
Joe Bob's Avatar
Is the engine and trans still out of the car?
2012 ML350 3.0 Turbo Diesel
Old 03-12-2021, 07:14 PM
No, original 2.0 with fuel injection and tranny are installed
Old 03-12-2021, 07:48 PM
RETIRED
Joe Bob's Avatar
You missed a good opportunity to inspect the clamshell.
I could pull the battery and put a borescope down inside the clamshell. It will give you an idea had bad the inside is. It rots from battery acid. If it's not to bad you can try an neutralize the acid with baking soda and water. Most will have a drain hole so you can flush it.
Was the battery tray replaced at any time?
Old 03-12-2021, 07:52 PM
All original.... battery tray rusted and needs replaced
Old 03-12-2021, 07:57 PM
RETIRED
Joe Bob's Avatar
Well before you do that, inspect underneath the tray inside the clamshell/hellhole.
Old 03-12-2021, 07:59 PM
That’s with the camera device right?
Old 03-12-2021, 08:07 PM
RETIRED
Joe Bob's Avatar
yup or a strong flashlight and your face down close.
Old 03-12-2021, 08:08 PM
Old 03-12-2021, 08:14 PM
RETIRED
Joe Bob's Avatar
OK, take out the battery and start digging. The clamshell terminates at a point down below and supports your suspension. If it's rotted out from the inside you right side of the body will sag down and no mas fun.
To replace it you need to order the part from Restoration Design. Cut out the old rusty crap and weld in the new pieces. That's where the bench comes in. I've seen rustier but you never know until you look inside the clamshell.
Old 03-12-2021, 08:19 PM
Old thread - But I'd love to see anyone with pictures of inside the clamshell where it terminates.
Rusty mess?
Or clean?
I'm trying to understand what I should be looking at when I walk a car to purchase.
Thanks!
J
Old 05-09-2025, 08:26 AM
Grappler
Rodsrsr's Avatar
Joe Bob is stating the worst case scenario. You don't need a celette bench to replace the battery tray. Most if not all of these cars will have surface rust below the tray.
If the battery tray and/or mount is rusted, there's a possibility the underneath is also rusted but not necessarily. My car has a somewhat rusted battery tray but underneath is close to 100% solid. It all depends on how soon you catch it, but the time to really see is when the motor is out. I would also pull the passenger side rocker cover to see how solid that area is. On my car its 100% solid behind the rocker, from under the car, and the top of the hell hole but ymmv. I happened to find a CA car that's been stored in a garage and sitting since the 90's with no battery so its fared well.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 06-08-2025, 09:04 AM
