Piston rings possibly sticking???? Additive to use?
I have a '73 914 2.0. The car sat for a number of years. We finally got things sorted out including fuel tank and lines. The car is now running great with lots of pep. Going downhill under compression she smokes blue. Compression showed all 4 great.
Someone told me the rings might be gummed up from sitting and therefore they stick and oil gets by. What do you guys think? Any additive that might help the rings free up or am I nuts? Thanks! Roger |
914 Geek
Typically when a 914 engine smokes on overrun (that's high RPMs with the throttle closed), the cause is worn valve guides. They let oil get sucked into the combustion chamber from the very high vacuum. Worn guides do not transfer heat as effectively away from the valves, and eventually that will lead to valve failure.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Possible worn valve guides or sticking rings around pistons
Dave,
Thanks for the info. I don't drive the car hard so Im wondering if the rings might be "sticking". Anything I do to find out or an additive I can run through the motor to see if it makes a difference? Thanks, Roger |
I agree with Dave, generally smoking on overrun is the valve guides as oil is sucked into the intake ports. If it were oil rings the smoking would occur also on acceleration.
I’ve had good results with old VW engines using Marvel Mystery Oil.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
I would heat it up and run it hard, both acceleration and decel. Adding Marvel Mystery oil to the cylinders wouldn't hurt.
1974, 914-6 GT Tribute 2007 Cayman S 1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten. 2017 Golf Sportwagon 4motion Exclusive source for the 914 Umbrella and Service cover |
914 Geek
The fix for worn valve guides is to remove the heads and have a good machine shop rebuild them. That should involve replacing the guides, grinding the seats, cleaning up the valves, and so on. It may find cracks that need to be addressed, and valve seats might need to be replaced instead of just cut.
An additive won't fix this. --DD
914 Geek
The only thing it will likely do is waste a little bit of time and a little bit of money.
The worst possible scenario is that something very incompatible with the oil gets mixed in, and the bottom-end gets destroyed. Very unlikely. --DD
