Tool for Measuring Body
Ok, I just about got my chassis all stripped and I'm ready to start making repairs. I have a slight sag so I will need make sure everything is straight before I do any welding. I have been reading the factory manuals on body repair and it refers to using a 2 meter caliper to check body demensions. Anybody know where to get a caliper that long? I found a 60" but it was $700+. That's a little more than I want to spend because I can't think of any other use for the tool once I finish working on the car. Is there any other tool that will work and is cheap? I guess I could use a tape measure but I don't think it will be very accurate.
Running Cars 06 Boxster S, 85 944, 83 928S Project Cars 74 914, 74 911, 72 914, 66 911, 65 912 |
The best way to check a car out and set it up for welding is to have it on a frame machine. Short of that, if you're any kind of carpenter, you know how to use a tape measure and a straight edge to layout anything. A 3 point laser is helpful. Forget the huge caliper and do it with the tape.
If you're on an absolute level workspace (very helpful), you can also use a drywall square to come up from the bottom plane of the car to measure to the corners of the winshield frame and such. This is what the 3 point laser is good for. |
914 Geek
You can also make a set of calipers. Just get something large that doesn't bend, but it in two, and install a hinge...
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
