Question Relay Board Question
On the main relay board in the engine compartment, is it ok for the round male conector pins to rotate slightly? Or, would that indicate a weak/broken solder joint?
TIA
Old 05-19-2003, 11:09 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
I believe that those joints are riveted, not soldered. I would be concerned about them rotating. (Hmm, if I were at home I'd go check my car...)
--DD
Old 05-19-2003, 12:41 PM
pbanders's Avatar
Send a message via Yahoo to pbanders
Riveted. If they rotate, they're unreliable. The fix is to remove the backing material in solvent, solder all the riveted connections, then repot the back to prevent moisture ingress. Yucky job.
Old 05-19-2003, 01:39 PM
