rear wheel hub spacing problem
I am running a hybird rear hub. 4 bolt converted to 5 bolt.
Vented rotors from rear 911
M calipers
having a rotor spacing problem
need to space rotor out from hub surface about 4 mm
Does anyone sell a flat spacer to fit behind rotor mounting surface??
Old 03-04-2022, 06:17 AM
I'm not sure if anyone makes a spacer but if you have a machine shop nearby, you might get them to make some for you. Why do you need a spacer? Is it rubbing/interfering with something?
Cheers, Elliot
Elliot Cannon
Paso Robles, Ca.
"Nationalism is an infantile disease, the measles of mankind". - Albert Einstein
Maintain thy airspeed, lest the ground arise and smite thee.
Old 03-06-2022, 05:42 PM
Emo993's Avatar
Roadsportusa, I made spacers for my standard rear five bolt hubs when I put 914 front calipers on the rear. I have two thickness, 4.2 and 6.2mm. Not sure which one's I used, car still in storage.'Just use thin washers as spacers to find the exact size, draw out a template and take to a machine shop as Elliot said. Best, Mark, just read your post again, you want to space out rotor, not caliper?
1974, 914-6 GT Tribute
2007 Cayman S
1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten.
2017 Golf Sportwagon 4motion
Exclusive source for the 914 Umbrella and Service cover
Old 03-07-2022, 03:33 AM
djpateman's Avatar
Yes, I have a few sets of those spacers.
the big rings here
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 03-12-2022, 06:10 PM
