iamchappy's Avatar
kill switch, ballast resistor install msd ign.
After installing the MSD 6A on the 3.0 I had the run on problem, which I also had on my 914 4 I have the ballast resistor I think the red switched wire attaches to it and a ground on the other side, do i also run another wire to the switched source. Also I would like to install a kill switch could I run a wire from my switch to the coil and what pole + or -.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 05-23-2003, 07:30 AM
norustscott's Avatar
Describe the run on problem....do you mean it runs on after you switch off power?
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 05-23-2003, 07:36 AM
iamchappy's Avatar
Yes, power is bleeding back into the system via alternator idiot light wire. I know i may need to solder a diode in the line, I have a ceramic chrysler diode but its been so long since it was hooked up i need a little help sorting it all out.
87 924S
Lexus SC400
Lexus LS400
Old 05-23-2003, 09:57 AM
airkwld's Avatar
I had the same run-on issue when I installed an Electromotive HPX unit. I placed the diode in-line between the voltage regulator and the charging light. Problem fixed and have not had any issues since. I think page 7 of the MSD installation manual details the diode installation, online version of manual is at http://www.msdignition.com/
I have the multi-pole kill switch connected to the ignition's main power supply wire.
Old 05-23-2003, 07:50 PM
