73 914 fuel tank - which is the feed line?
Fuel tank has two fittings on the bottom. One a feed and the other a return. There is a larger diameter line and a smaller Which is the feed line?
Old 09-26-2022, 02:54 PM
BoxsterGT's Avatar
Porsche Crest
Larger one is the Supply to the Fuel Pump at the rear, similar to the early CIS 911's with a rear pump.
Best to relocate your fuel pump up front if you can. It runs better up front. Pumps are better pushers than pullers.
Len
Old 09-26-2022, 04:33 PM
Len
Thanks Len - Hmm, I agree. How much space is under the tank?
Old 09-26-2022, 06:44 PM
dr914 ***********
pass side is the feed drivers the return. 70-74 have a larger feed and a smaller return 75 76 have the same size for both
Old 09-27-2022, 10:04 AM
Thanks, I got it all back together and figured out the larger diameter line with the tall screen on it. The hardest part was getting the hard line through the tunnel. I didn't realize I could have popped off the front interior cover and easily guided the fuel line through the opening under the tank. Just needed the one line as its a Lt1 running a carb
Old 10-05-2022, 08:25 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Wow, Tamar, you really sound like a spammer attempting to look like a forum member without effort.
Are you?
--DD
EDIT: He was, in fact, a spammer. He came back later and edited in the link he was trying to promote. Bye bye, spammer!
Old 10-13-2022, 09:39 PM
carbs deserve a return line also
all cars deserve a return line..
cooler fuel, more HP, and better in all ways.
914/6 2.0S with twin plug
all metal body panels
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 11-23-2022, 12:50 PM
Are you?
--DD
I am severely changing my process for dealing with new members, spammers, for sale with no post count, etc. Getting tired of putting up with all of this.
Old 11-23-2022, 01:22 PM
Funny you mentioned that Brant. We were talking about that in your garage last month. I got back home and a few days later, my capped return line started leaking and spilling fuel in the car while I was doing a routine monthly warm up. With somewhere to go that might not have happened. I am joining the return line for carbs camp.
Old 11-23-2022, 01:24 PM
Glad you found the leak before anything bad
Happy thanksgiving!
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 11-23-2022, 02:11 PM
