Bruce Allert's Avatar
Will this sway bar work?
I'm wantin to put a sway bar on Punkin and need advice on this one that's on Ebay.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&category=33592&item=2418614146
Would I be ahead to get a new one?
Just drove a 2.0 with the sway bars. What a difference.
So, need some help guys......
thanks,
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Gotta mow the Lawn...
Old 06-09-2003, 09:52 PM
mike mueller's Avatar
As long as you don't pay too much, I'd say go for it
(last time i sold a factory bar like that I let it go for $75)
$100 is okay , but after that I'd save my money for an aftermarket unit.
One tip: Drive the car until the tank is darn near empty, it's a pain to have to drain 10 gallons while under the car...(did this just this past weekend)
'73 914, 1.7, with Boxster transmission in the future?
Old 06-09-2003, 11:01 PM
Thanks Mike, Was looking at the Weltmeister on Pelican too. Is the quick mount just as good so the tank doesn't need removing?
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Old 06-10-2003, 06:19 AM
914 Geek
NO!!!!!
'Scuse me for shouting...
I really think the "no tank removal" installation kit is junk. It's two U bolts that you have to push in through the hole you drill for the bar. No reinforcements, so you're just going through one thin layer of sheet metal. Plus you may run into problems with the square-section reinforcement at the bottom of the tank compartment.
I strongly do not recommend that installation kit. Go ahead, remove the tank--it's not that hard!
The 19mm bar is not a bad option, either. It is definitely more expensive ($300+), but it is adjustable. You can use it to fine-tune the balance of the car--or you can use it as something to keep tweaking to the point where you stop concentrating on driving... (Been there, done that!)
The stock bar, particularly if you can pick it up cheap, is a good option. You'll want the "remove the tank" mounting kit, and you'll want the "U-tab" kit. Those will increase the overall cost of the install.
--DD
Old 06-10-2003, 08:44 AM
Thanks Dave,
When ya comin up to see yer Mother? Gonna make it for Jamies 914 get together?
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Old 06-10-2003, 09:41 AM
914 Geek
Not sure on either count yet...
--DD
Old 06-11-2003, 09:31 AM
Bruce:
Were it me(and it was), I wouldn't screw around with a non-adjustable sway bar. Do some shoppin' for a 19mm (or22mm) Welt bar....new, used, whatever. Tarret is very nice for another hun and a half.
JPIII
Early Boxster
Old 06-11-2003, 12:19 PM
JP, I agree wit'cha...
I been looking at the Welt. I also called Gary at Parts Obsolete. He said he has some. When I spoke to him I didn't specify adjustable tho so I gotta make another call to 'im.
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Old 06-11-2003, 12:29 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
The S/B that mounts to the floor of the trunk will tear the metal unless you use a backing plate and round off the sharp corners. Steve
Old 06-12-2003, 07:44 PM
RETIRED
Joe Bob's Avatar
Smart Racing makes one that is REALLY pretty and well engineered....cost a few scheckles more than the Weltie though....
2012 ML350 3.0 Turbo Diesel
Old 06-12-2003, 08:13 PM
chrisreale's Avatar
I copied JP and got the Tarett bar. Its 22mm. If you get a 22mm bar, ya might as well stiffen the front up with some 22mm torsions, and while you are at it, bushings ball joints and wheel bearings......and while you are there also......
What is your current set up?
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 06-12-2003, 08:38 PM
Currently... 0 (zero)! Absolutely stock, start at the beginning!
I figure I'd start with the sway bars then go for the 2.0 when one comes available.
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Old 06-12-2003, 10:00 PM
