BCinSC's Avatar
Send a message via AIM to BCinSC Send a message via Yahoo to BCinSC
How often should you change...
The fuel filter?
Spark Plugs?
Condensor (Points)?
Brake pads, F vs R?
Pack Front Wheel Bearings?
I'm looking through the history of my car and am shocked at how often these things were done. Though I can do nothing about it, I question whether the dealer actually did them each time, or just took the poor guy for all he had.
'73 914 1.7L White aka Blanche
Old 07-06-2003, 07:29 AM
jamcleod's Avatar
Send a message via AIM to jamcleod
according to my haynes (couldn't quickly find in the workshop manual):
every 3k miles: oil and filter change
every 6k miles: valve adjust, check: dwell, plugs, timing
every 12k miles: compression check, replace: fuel filter, spark plugs, air filter, points
every 24k miles: replace brake fluid
brake pads: when 2mm thickness
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 07-06-2003, 01:48 PM
Ornery Bastard
Points: When the tach gets sloppy.
I don't bother with the bearings unless they are getting noisy.
15,000 miles is the maximum that I'd put on copper core plugs, 12,000 is better. If you're using platinums, just check the plugs every 12,000 but platinums ought to last 2-3 times as long as copper plugs.
Brake fluid for me is every 2 years, regardless of mileage.
The valve adjustment for my 1976 2.0 is 12,000 miles.
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 07-06-2003, 03:14 PM
