Frozen nut
Attempting to take the exhaust header off I rounded over one of the nuts. I tried a 13mm socket which slipped, so next was a 12 mm which did not fit on it. Tried a 1/2 in socket on the next nut and it came off as did the rest. Only one stuck was the one I tried first, nicely rounded over by now. Bad place to ground the nut off since I can't get to it
I had a pretty good idea. I applied a bead of thick CA (super glue) to the inside of the 1/2 in socket and sprayed CA accelerator on the not. Stuck the socket on the nut, let the glue harden and easily undid the nut. Neal |
Neal,
I've never thought of that method but it sounds like a great Idea. I've rounded a few nuts myself. JB Weld might work too. Of course, your socket will never be the same. Vern |
I did not clean the oil/grease from the socket before I applied the glue. The hardened glue popped right out.
If you use JB Weld or other epoxy, heat will soften the glue (I think). Neal |
Ive had my tounge stuck to a lamppost in the middle of winter,
but never a frozen nut. sorry cant help. |
who's lamppost was it stuck to? (lol)
that's sick and uncalled for.
Now that I think of it, maybe ask the owner of the lamppost. Good possibility he had a frozen nut.
Yeah, maybe. But frozen or not, he probably wouldn't want it glued into a socket and twisted off!
you dont know the owner of the lamppost
wow, I didn't know so many pelicans were into that scene. Whatever floats yer boat i guess... :-D
Uh I was kidn :/
Geez man, get your tounge stuck on one pole, and then they label yah as a .... Last edited by tod914; 08-02-2003 at 03:54 PM.. |
I need an athletic cup...
m
I wish I had a dime for every penny I ever had. http://www.914club.com/bbs2/uploads/blog-1136350347.jpg |
hmmm, do those come in leather?
